D
DarkJediUK
I'm trying to find a decent brand 26" LCD which sports dual component input, and DVI if possible, so that I can replace my ageing widescreen Sony 28" Trinitron hunk of junk... Unfortunately I don't have much space (or cash!) to fit the new TV in, but this one really does need replacing! Of course, if you can fit a 32" into that budget, I'm sure I can showhorn the screen in somehow
I don't need it for much, but I would like the display to be crisp; the two component inputs will be used for Xbox360 and Wii, and DVI for my pc now and then.
I don't realy have a budget, but I suppose if you can keep it under £500 it would be great. I'm getting very bored trapsing from website to website, so thought I'd ask you lot as you seem to know everything
Thanks in advance
Thanks in advance
