26" LCD revisted
Discussion in 'LCD & LED LCD TVs Forum' started by fred3939, Jan 14, 2005.
Tags:
  1. fred3939
    fred3939
    Nov 25, 2003
    11
    Does anyone have any comments/reviews on the Video 7 V7LTV26C 26" LCD TV which is currently being sold on Ebuyer for around £ 680.
    From the specs it gives on the site, it looks failry impressive for the price.
  2. boneman
    boneman
    Here are the specs if someone with some knowledge wants to comment
    I am also interested in knowing if this is a good buy or not
    Panel Size 26" LCD Panel (66,04 cm)
    Viewable Size H x V 566.4 mm x 339.8 mm
    Aspect Ratio 15:9
    Pixel Pitch (HxV): 0.443 mm x 0.443 mm
    Contrast Ratio typ. 600:1
    Brightness typ. 600 cd/m²
    Response Time 25 ms
    Viewing Angle H/V 170°/170°
    Resolution 1280 x 768 (Wide XGA)
    Systems PAL/SECAM-B/G, D/K, I, L/L
    Power Consumption max. < 125 Watt
    Cable Tuner (Hyperband) Auto/Fine
    Programming
    Stereo (Virtual Surround)
    Sleep/On Timer
    PIP-Function (Picture-in-Picture)
    HDTV, Progressive Scan, Digital Combfilter
    Teletext (100 pages)
    Speakers 2x 14 Watt
    Features Silver Design, wallmountable (VESA 100 mm)
    User Control Multi Language OSD
    Video Input 15 pin D-Sub, VGA
    Input Antenna, 2x Scart, S-Video, DVI, Audio L/R, Component YUV (Y/Pb/Pr),
    PC Audio
    Supply User Manual, Remote Control, Batteries, Power Cord, Antenna Cable
    Dimensions WxHxD 662 mm x 510 mm x 245 mm incl. stand
    Weight 13 kg incl. stand
    Warranty 2 years Pick-Up Serviced
