26" HD LCD TV - what to get?
soil
ok im so unsure on what to get now, i was planning on going for the "Lg 26lx2r" but i have gone off it big time from playing about with it at comet, and how it looked, was just to wide with the side speakers.
i liked the 26" sony but i realy dont want to pay £650 for it.
after something for around £500, £550 max.
will be used for watching films (from my pc, NOT a dvd player or any game consoles) it will be at the end of my bed, also might be used for a normal PC monitor, dapending on how it looks and if i think my eyes can take it!
not to sure on which make but probly any of these:
LG
SAMSUNG
SONY
PANASONIC
any to recommend?
:confused: :rolleyes:
dickst3
I have just bought the Sony, but with a budget of £550 I would have been as happy with a Panny - my wife wanted the Panny for looks! :rolleyes:
juniper
LG
SAMSUNG
SONY
PANASONIC
any to recommend?
Have you considered one of these from Novatech?:
http://www.novatech.co.uk/novatech/products/a835x1y0z1p0s0n0m0
27" version for £449.
soil
well done abit of searching again,
kinda gotten my eye on the "LG 26LC2R" ill go to comet some time and have a play with that 1.
the only other 1 i like so far is the SONY, but £650 is just to much :(
does anyone here have the "LG 26LC2R"? if so could u say what u like about it and if anything what u dislike about it...
Hungry_Joe
Except i thought that thing couldn't be connected to pc. I may be wrong - after all i was wrong about thinking puppies tails grew back after being pulled off.
pixelated
The LXD60 doesn't have a VGA input unfortunately. Panasonic should be releasing a new LCD TV soon....... I think .... ?!?!?!? that does.
skunk123punk
Ok, if you want some informed feedback then I can vouch for Samsung, I have the LE32R74BDX/XEU, LE26R41 and the LE40R74BDX TV's and can say confidently that they are the bees. also after he sampling the LG and Sony range (I have a LG Plazma as my main display so no bios)
Really? Will there be a new Panasonic 26" before October?
skoov
If it helps just got Sony KDL-26S2010.Thanks to decent advice from this board(thanks to Lyris and Stuartd)
Main use:pC and SD signal(analogue!)
Delighted with the picture quality,much much better than i dared hope.A nice step up from a 21" Grundig crt :thumbsup:
PC is great,but recommend decent cable and graphics card,unless you like your mouse cursor to have lots of ghost friends.
Only snag is lack of picture in picture(would be nice to surf net and have small tv in corner of screen),should have checked this but assumed(never assume!) all modern lcds had this?
I compared JVC and Sony side by side in shop and there was little in it,Sony won for its text clarity.JVC looked a bit cheaper on the build quality side.
soil
oh cool thanks,
besides it not having PIP is there anything else u dislike about it. well not dislike but u kinda know what i mean...
i would think that ud need a good cable for any TV to use as a PC monitor to stop the ghosting then, not just in the sony.
good graphics card isnt a problem, got me a 7600GT :D
which port did u connect it to ur pc on? the VGA?
i take it VGA cant take HD?
could i then use the Y-Pb-Pr from my graphics card to output HD to the TV?
oh what HD formats can it take?
skoov
Hi Soil,yep the VGA port, HD (720) will be fine
the pc i'm currently running through it has a pitifull graphics card tried to run Media Portal and it just laughed at me.:hiya:
So,once my new Radeon 9250 arrives i'll let you know about hD.
Not sure if it accepts DVI via the HDMI?anyone tried this?
I tried my Vaio laptop thru it as well and ran a 720p Madagascar clip,very nice indeed :D ,i'm sure your setup will be awesome for HD
snagwise,only the PIP really,gotta say its best tv i'v ever had,got a good price thru Dabs,other people see it and go "ooh"
soil
:thumbsup: thanks again.
iv noticed some sites have U at the end of the model
whats the U all about? or is that just the same thing or what? :confused:
Hungry_Joe
I believe the U means the Tv is made of Uranium, and liable explode in a horrific thermo nuclear way should you watch dross like neighbours or something. Actually that would be quite good - entire swathes of big brother watchers eliminated. As they should be.
That or its a UK model and they can't be <hmm how liberal is this site> arsed to put UK.
soil
:confused: u confused me!
i just did abit of search and the U version is cheaper which should i get? :rolleyes:
http://uk.shopping.com/xSBS-flat_panel_televisions-kdl_26s2010~PRDLT-32099440-32099433
just woundering but how come it says its got PIP when errmm skoov said his doesnt? have they changed it so it does or something?
chocky909
They are the same TV. The full name is KDL-26S010U Just that some sites call it slightly different names. Go for the cheapest one.
Also the TV does NOT have PIP. Some photos make it look like it has but this is just the 'pause' function (pauses main image while live pic continues in a smaller box in the corner).
Don't believe specs on those websites. If you want to know the specs then go to the Sony website. You can probably even download the PDF manual.
Similar threads
Trending threads
Latest News
Marantz unveils 12 Series Special Edition models
  • By Andy Bassett
  • Published
Samsung Galaxy Note 20 smart phone models launched
  • By Andy Bassett
  • Published
Toshiba launches UK4B 4K Alexa enabled TV
  • By Andy Bassett
  • Published
Mulan to premiere on Disney+ on 4th September
  • By Andy Bassett
  • Published
Has Amazon Prime Video dropped Dolby Atmos?
  • By Andy Bassett
  • Published
