26"/32" LCD for PC Games
Discussion in 'LCD & LED LCD TVs' started by J_men, Sep 21, 2005.
  1. J_men
    J_men
    Hi Guys
    I'm looking for a screen that will be primarily used for PC games, i.e. Counter Strike, BF2, Doom 3 etc. So I want one with a really good response time, but all the manufactures all measure them differently. Is there anyone with first hand experience of some good screens??? Will be using a DVI or D-SUB connection.
    I've had a quick look at these:-
    Acer AL2671W
    Acer AT3201W
    Samsung LT-P266W (Not sure if model number has changed)
    Syntax LT27HV
    There's quite a big price difference (£600-£800) between them so is there a big difference in quality. And also is there much difference between 26 and 32 inch screens apart from the size???
  2. vipergrm
    vipergrm
    Sep 6, 2005
    3,748
    Belfast
    +565
    Hi J-Men, I recently purchased the Acer AT3201W and the build quality is excellent. I was playing Gran Turismo 4 on the Playstation last night and it looked really well with absolutely no lag. It has a response time of 12ms and should be fine for your gaming needs, especially at £800 for an HD Ready 32" TV!
  3. knowley
    knowley
    Jul 18, 2005
    82
    9
    BF2 is fantastic on a 32" but you might ahve to install PowerStrip to get the gamma and brightness right.
