26-28" Telly - TX26LXD500?
Discussion in 'General TV Discussions Forum' started by KiNeSiS, Jul 6, 2005.
  1. KiNeSiS
    KiNeSiS
    hey peeps, i am looking to get a sweet 26 - 28" lcd to go with my pioneer H530 dvd rec thats on its way...
    i was originally looking at sonys etc for about 700 quid but then came across this baby:
    [​IMG]
    TX26LXD500
    now my question is: is it really worth the massive extra cost for the HD compatability, image quality and freeview integration? or should i get a regular 27" from sony or whatever? it does seem like a whopping amount of cash!
    NOTE: i will be getting a PS3 so i assume HD is a must? or will it not really be all its cracked up to be?
  2. KiNeSiS
    KiNeSiS
    anyone got any ideas? i could really do with some input before i make my purchase...
  3. ResB
    ResB
    Feb 10, 2004
    UK
    +7
    I'm looking at the same model. The TX26LXD500 seems to be the one to go for as far as I can tell. However, the image you are showing is the TX23LXD50 . The 500 is about £1,500 and the 50 is about £1,200. Of course you can get them cheaper online.
    I really fancy the 500, look great, just wish I could find somewhere who had a demo up and running.
    [edit]
    Inserted Images.
    [​IMG] [​IMG]
