256MB Nvidia geforce go 7600gt good or bad?
Discussion in 'Computer Components' started by jpb82, Apr 29, 2007.
  1. jpb82
    jpb82
    Nov 22, 2005
    800
    Rugby
    +18
    Im currently looking for a new notebook and most
    of the notebooks im interested in have a
    256MB Nvidia geforce go 7600gt graphic card.
    As i dont know to much about graphic cards
    could anyone tell me if this card is good enough
    to play past and current games reasonably well
    say at a resolution of 1024x768 for example?
    Thankyou
  2. gargoyle
    gargoyle
    Nov 8, 2000
    630
    birmingham
    +24
    Yep, the 7600gt is a superb budget card which'll play the latest games comfortably at the resolution you suggest.
    A decent cpu would improve matters considerably.
  3. jpb82
    jpb82
    Nov 22, 2005
    800
    Rugby
    +18
    Could you also let me know how the
    256MB Nvidia geforce go7600 handles current games as well, because which ever system i end up getting will probably have one of these cards in it.
    p.s. is there really a performance difference between the 7600 and the 7600gt or are they basically the same card.
  4. Chox1988
    Chox1988
    Mar 30, 2005
    16,793
    basingstoke
    +9,161
    Yes the go7600 will play games at ease under those resolutions at the highest qualities :thumbsup: .
  5. Windtalker
    Windtalker
    Jul 8, 2005
    1,703
    48
    newcastle
    +51
  6. ssjaronx4
    ssjaronx4
    Oct 12, 2005
    100
    +4
    My Acer has 7600 and i can say youll be able to play most new games with ease. As an example, when i bought the laptop last september I got Quake 4 and am able play @ 1360x768 resolution with either max settings or the same resolution @ high settings with 8x AA. So its not a bad card although they are about to bring out the 8 series mobile cards soon so it may be worth waiting a month or so and getting a laptop with one of those in and the latest Intel processors.
  7. jpb82
    jpb82
    Nov 22, 2005
    800
    Rugby
    +18
    Thankyou
    its good to know that if i buy a laptop that has the
    256mb nvidia geforce go 7600gt graphic card it should
    be good enough for what i want to use it for.:thumbsup:
