250+gig hard drives..
Discussion in 'Computer Components' started by Peter Parker, Aug 9, 2004.
  1. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,269
    UK.
    +2,792
    Are there any problems fitting hard drives of 250gig or more in a moder PC running Win XP? I thought I read that 137 was the max, but want to be sure before I get some. :)
    TIA
    Gary.
  2. MikeTV
    MikeTV
    Feb 1, 2003
    7,782
    Ealing, London
    +842
    XP has no problem with it. I think it depends on the motherboard. You may need update your mobo bios - it depends on the make/model of the motherboard.
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,269
    UK.
    +2,792
  4. Master Rahl
    Master Rahl
    XP has issues if you try to install it on a hard drive > 137 GB. Once you have it installed and can install proper drivers, it won't have a problem.
  5. Ajax
    Ajax
    Feb 4, 2004
    170
    Hello,
    I have a 250Gb Hitachi Deskstar in mine and XP recognised it instantly.
    Ajax.
  6. MikeC
    MikeC
    Mar 14, 2001
    225
    Northants,UK
    +10
    IIRC, I thought this was a problem fixed by the SP1 fix - I could be wrong tho.....
    Mike
  7. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Just to add a comment, the feature you need to have is 'BigLBA Support', which is also known I believe as '48-bit'.
    AFAIK the >137Gb installation issue is that the installer which is on the original XP release CDs doesn't have BigLBA support in it, whether version with SP1 slipstreamed on them had that added I don't know.
  8. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,269
    UK.
    +2,792
    Thanks for the info - I'll just try installing XP then SP1 and see how it goes.
    Cheers.
  9. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    The guys one here are correct if you have xp + sp1 installed i will recognise over 137gb i know as i have installed a 180 today and it worked fine format it with the small cluster size as poss that way you get more on disk space but a little less performance its your call :)
  10. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,269
    UK.
    +2,792
    What about a new install, where the primary disk is 250gig and you need to install Win XP on it? Does it see it as 137 until SP1 is installed? I can format them on another machine first, then install them into the new machine for putting XP onto. Would that make it easier?
    TIA
    Gary.
  11. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    me personally i only configure a 30GB os partition as a primary that way it keeps your media files seperate (mp3, movies etc ) from your os configuration and it is easier to backup the os using something like ghost as you can image onto your d:\drive then next time you want to rebuild it takes the hassle out of the whole proccess you just load up ghost and read the image from d:\
    thats my personal preferrence and thats how all my customers get there kit delivered :)
  12. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,269
    UK.
    +2,792
