alphaomega16
H O L Y ****
Sniper Ash6 said:Hopefully you mean bytes and not bits
They are technically right though, 2019MBps is greater than 2GBps. It's not greater than 2GiBps though.
Just after 1:50 the guy says we beat 2000 megabytes per second with it showing 2019, the the overlay on the video says they broke 2 gigabytes per second. Correct me if I'm wrong but don't they need to break 2048 megabytes for it to be 2gb, not 2019?
The SI definition of mega and giga are 10^6 and 10^9 respectively. Therefore 1000MB = 1GB. 1024MB would be 1GiB - the binary prefix.Just after 1:50 the guy says we beat 2000 megabytes per second with it showing 2019, the the overlay on the video says they broke 2 gigabytes per second. Correct me if I'm wrong but don't they need to break 2048 megabytes for it to be 2gb, not 2019?
I wonder what it did to his access times though - throughput is great and all but the real benefit of SSD is access time not throughput.
Wow, I remember this, this is old!
If you buy two OCZ Agility 3 drives and put them in RAID0 then you get 1GB/s read and write, things have really quite moved on.
