24p
Discussion in 'LCD & LED LCD TVs Forum' started by vali23ro, Feb 7, 2009.
Tags:
  1. vali23ro
    vali23ro
    Jan 30, 2009
    46
    Is 24p feature something that affects the TV when you are playing movies from PC?
  2. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    You can output 24p via HDMI/DVI (CEA mode) from ATI HD3000 and HD4000 series. Not sure about the other ATI series and nVIDIA cards
  3. Restorer
    Restorer
    Dec 15, 2002
    1,128
    63
    NE England
    +141
    Yes, I output 1080/24p from my Geforce 8800 under Vista no problem.
  4. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    that's good to know:smashin:
  5. vali23ro
    vali23ro
    Jan 30, 2009
    46
    i meant if i will buy a LCD TV that doesn't handle 24p well would it affect me if i play AVI & MKV from my pc? I will use the TV in 60p, just as a regular monitor. The regular monitor plays AVI & MKV with no judder, will the TV act the same?
  6. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    playing 24p contents @ 60Hz will cause judder (even on monitors)
    but it seems you're not affected, so I guess you'll be fine with a standard set
  7. vialli25
    vialli25
    Aug 21, 2008
    65
    11
    Hornchurch, Essex
    I'm guessing your AVI and MKV files won't be encoded at 24 frames per second. Therefore the TV does not need to be able to display 24 frames per second.
    24p is a feature that is mainly used with Blurays as they are encoded in 24 frames per second. When playing these 24p films at 50 or 60 frames per second you will get judder.
    But seeing as you're only going to be outputting 60hz from your PC you will be fine with a 60hz capable TV (which is most TVs!).
  8. Mumid
    Mumid
    Dec 20, 2007
    1,541
    +327
    Most MKVs are incoded in 24fps. To the OP, I wouldnt worry, the TV plays 24hz fine from a PC.
  9. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    Most AVI, Divx. MKV etc... movies are encoded in 24p.
    So if the OP want judder free motion, he needs a 24p capable TV and GPU.
  10. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    not all of them
  11. vali23ro
    vali23ro
    Jan 30, 2009
    46
    Well i hooked up my 32A450 720p tv, wich is in no way 24p capable and tryied alot of avis & mkv. no judder at all. so i guess my question is answered now. 32A656 won't be a problem for me as a PC monitor
  12. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    what is your definition of judder?
  13. Mumid
    Mumid
    Dec 20, 2007
    1,541
    +327
    Yeah, he was talking about getting an A656 though which is what I was reffering to
  14. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    oh ok
