~24inch 1080p Screen for PS3 (£200)
Discussion in 'Computer Peripherals & Consumables' started by decmatt, Feb 9, 2009.
  1. decmatt
    decmatt
    Dec 16, 2004
    15
  2. Facct
    Facct
    Jun 29, 2005
    28
    BenQ e2400hd can be had for £200 and would probably be my choice, I just bought the e2200hd and was seriously considering the e2400hd
    You might be able to find the Dell S2409 for £200 and is supposed to be comparable to the BenQ. Although someone mentions a sound issue in this thread: http://www.avforums.com/forums/computer-monitors/923927-250-spend-monitor-ps3-blu-ray.html
    The iiyama E2407HDS that you posted on the 2nd link (as Acer H243) doesn't have a headphone socket, so you would need to connect your audio separately, rather than getting it through the headphones via HDMI, the speakers no doubt suck (someone mentions they suck in that thread linked above)
    I tried looking for info on the Acer XH243, I don't think it has HDMI, only DVI with HDCP, which means you can only get video through HDMI (using an HDMI to DVI adapter) and would have to connect your audio separately. I couldn't find this priced anywhere for £200 though, but I did find the 23" model for £200, the Acer X233H
