Quantcast
24Hz, 50Hz and 60Hz source
svanur08
Was wondering how does this work on LCD/LED tvs? If the TV has refresh rate 60Hz and plays 24p content like blu-rays, it does 3:2 pulldown, and 5:5 pulldown if it´s 120Hz without judder as i understand it.
What about 50Hz source, does refresh rate change on the tv to 50Hz refresh rate on 60Hz tv, and to 100Hz on 120Hz and 2:2 pulldown, Or some other pulldown from 60Hz to 50Hz?
AndyRg4
Most UK TV's will be able to natively display all of these refresh rates without any pull down
svanur08
I have a Samsung UE50KU6000 tv with native 60Hz refresh rate, so are you saying it changes refresh rates between sources like 60Hz, 50Hz and 48Hz for 24p?
mike7
Yes, it must do to function. I would suspect using pull-down techniques.
Trollslayer
Display panels can run at different rates.
Some can do 50 and 60Hz, some 24, 50 and 60Hz etc.
Trollslayer
No.
AndyRg4
I suspect it´s 50Hz and 60Hz switches between them and 3:2 pulldown for 24p content. :/
24 frames are displayed natively at 24 frames on most TVs. The pull down method is only needed when playing say 24 frames content on a TV that doesn't natively support it
dannnielll
The old analogue TVs with the CRT displays were very inflexible with regard to changing frame rates. This is because the circuitry used to generate the raster.. the spot moving over the screen was linked to power supplies for efficiency. With digital screens, it's a much simpler process. There is a block of memory assigned to the screen and it basically does not matter within reason how often it is refreshed.
grahamlthompson
Any TV described as 1080P HD Ready will natively display correctly without pulldown provided the source is capable. eg When connected to a blu-ray player you get 1080p24. Many UK set top boxes and media players however will only work at 50Hz even when the source file is 24p or 60p.
HD ready - Wikipedia
Similar threads
