24" widescreen tv
Discussion in 'General TV Discussions Forum' started by BallJoint, May 19, 2002.
  1. BallJoint
    BallJoint
    I know this is the lower end of the market, but does anyone have any advice on 24" models. I can't afford the Sony KV24LS35, although it has great reviews.
    I have been looking at more reasonably priced alternatives, especially the Panasonic TX24DX1 and the Philips 24PW6006.
    Has anyone come across either of them, are they good value for money? A shop told me they are the same TV but in different cases - is this true?
  2. Squirrel God
    Squirrel God
    Philips are using Panny tubes in their 6006 now as well? :eek:
    Do a search for the "PW6006" and the "DK1" in general on this forum to get some views (I presume you meant the DK1 as I haven't heard of the DX1).
  3. headache
    headache
    Like you 24in is big enough, but we are in the minority here.
    I have also been comparing Philips 6006C and Pany TX24DX1 (yes DX1).
    First impression: Philips looks better. Pany looks old fashioned box and its stand does not match well.
    Facilities: Pany has more. Better remote handset.
    Price: Philips is cheaper by some £30.
    I also considered JVC once but suggest read other postings first.
    keep the ball rolling.
  4. Mr Cheese
    Mr Cheese
    Dec 12, 2002
    412
    Down South
    +19
    I bought the JVC for the kid's den. Does the job well although the sound is rather weak. Ok for them though. I don't particularly like silver tellies. Got this one in black AND listed at £30 Cheaper than silver!
    Mr Cheese.
  5. Garrett
    Garrett
    Apr 21, 2001
    39,887
    2
    167
    The best thief you’ll never see.
    +6,543
    If you are getting a W/S this small I think you may be better going for a 28” 4:3 as I think(could be wrong) that this will give you about the same size picture in the W/S mode and a lot bigger in 4:3. On the other hand if room is not at a premium the W/S is better.
    Lastly you would be better though if you could get a 28W/S.
