24" Widescreen Telly advice
Discussion in 'General TV Discussions Forum' started by spikeyboyo, Feb 28, 2003.
  1. spikeyboyo
    spikeyboyo
    Im looking at getting a TV for the bedrrom to replace the old 14" one i have - so any advice people can give me as to which makes/models are good please.
    Spike
  2. afleming
    afleming
    Feb 6, 2003
    47
    manchester
    When i was looking for one of these i ended up with the sony 24" which is kv24ls35 at the mo is a t comet online for £434. i paid 484 for this.
    Basically there are flat screen 24" and their are non flat screen models.
    The non flat screen models are approx between £270 and £350 and there are ones by samsung ( good picture) philips, and panasonic.
    If you want to pay a bit more there is a two phillips models one with a buit in dvd. These were 429 without and 529 with.
    Their pictures looked good, but i had it side by side with the sony and opted for the sony.
    hope this helps.
    Bythe way the sony one does not come with a stand this is extra, butas i put it on my bedroom table it didnt matter.
  3. missin
    missin
    Mar 1, 2003
    202
    +5
    spikeyboyo
    in the same boat as you can't decide which one
    just seen this on the argos site under £200
    Bush WS5673SIL 24in Widescreen TV
    Cat.No. 537/4511
