Quantcast
24 inch widescreen tv - Sony??
A
anthonys
Hello
My faithful Ferguson 20" tv is showing its age - well it is 14 years old!
Has anyone any experience (good/bad) of the Sony KV24LS35, which is about a s big a set that will fit into the corner of the living room?
There are very few 24" TVs around now, and have heard reliability problems re the Philips.
Any comments welcome
Stew
steve1056
I purchased this TV about 6-weeks ago for my kids and have found it to be superb. Picture (including Geometry) and sound are excellent for the money.
A
anthonys
Thanks, Steve.
1 +ve so far!
Did you buy via shop or e-mail?
Stew
Brox
I bought one about a year ago, the first one was replaced because the geometry was noticably out the second one whilst I could detect a slight problem was not worth worrying about.
I like the tv and am happy with it, the only problem is if you are feeding the output from the audio outs to an amp you will need to turn off the internal speakers - the trouble is when you turn the tv off and on again you have to repeat this. When I bought mine there were no other flat screen widescreen tv's of this size - don't know if there is now!
steve1056
Stew,
I bought mine from John Lewis in Reading. Cost £479 with a 5-year guarantee.
Cheers,
Steve
