24 1st series replacement discs
Discussion in 'Movie Forum' started by Dellboy, Jul 21, 2003.
  1. Dellboy
    Dellboy
    Apr 24, 2002
    602
    43
    The Cotswolds
    +135
    Has anyone had any trouble getting the replacement discs from Fox for 5&6 of the dvd's for the original issue of this series?
    I sent mine for replacement over 2months ago. Nothing yet.
    Does anyone have a contact number or address I can use?
    Many Thanks
  2. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    Cant you just use the address you sent them to in the first place? or do you mean email?
  3. Dellboy
    Dellboy
    Apr 24, 2002
    602
    43
    The Cotswolds
    +135
    I would like an e-mail address or better still a phone number so I can contact Fox to find out what has happened about my discs.
  4. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
  5. Dellboy
    Dellboy
    Apr 24, 2002
    602
    43
    The Cotswolds
    +135
    Brill!!!
    I'll give it a go.
  6. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    Their customer servive is pretty good, they sent me a replacement aliens box set box for nowt. So im sure they will be able to help with your repacment discs.
  7. MrFurious
    MrFurious
    Sep 9, 2000
    14,969
    137
    Cardigan Wales
    +1,887
    just got a 24 series one set on dvd,what was the problem with the discs and how can i check if mine are ok??
  8. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    A brief search of the forums will let you know, cant remember exactly whats wrong ith them but mine were fine when i bought them
  9. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    AFAIK they were mistakenly the US edit rather than the UK edit (as shown on BBC), which is a few minutes longer per episode. Only affects the last two discs.
    StooMonster
  10. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,767
    2
    In a secret location with Jennifer Lawrence
    +9,562
    If you have a look at the 5th and 6th disc on the front there should be something like V1.01 or similar. Can't remember what exactly. If you have the newer correct version it should say V1.02 or V2 or similar.
    Greg
