2307 Died.
Discussion in 'AV Receivers & Amplifiers' started by hottstuff, Sep 2, 2007.
  1. hottstuff
    hottstuff
    Dec 20, 2005
    3,617
    Rep. of Ireland
    +149
    Looks like the video board of my 2307 died.
    All i get is a green screen from all sources.
    Anyone else have any issues similar to this?
  2. Jase
    Jase
    Mar 16, 2001
    10,936
    United Kingdom
    +3,284
    Have you tried resetting it in case it's just a glitch?
  3. hottstuff
    hottstuff
    Dec 20, 2005
    3,617
    Rep. of Ireland
    +149
    If by that you mean unplugged it & disconnected everything then reconnect , yes.
  4. Bagger
    Bagger
    May 8, 2007
    2,225
    Leicester
    +227
    You might need to reset the microprocessor
    Page 44 in your manual
    1 switch off the power
    2 hold speaker A+B buttons press the power button
    3 check the entire display is blinking with an interval of about 1 second and release your fingers from the 2 buttons
  5. hottstuff
    hottstuff
    Dec 20, 2005
    3,617
    Rep. of Ireland
    +149
    It only happened this morning when i switched on , so didn't have the time to check the manual today , but yes spot on mate , it worked a treat.
    Thank you.
    Was worried i may had to send it back to LE.:smashin:
