M
Morry1989
Hi all
I'm looking for an HDTV 16:9 screen which is 23". I'm not sure which one to go for, I've had a look around and the old Samsung LE23R41B is going for £450 at play.com. I'd like to use it with an xbox 360 and was wondering which is the best panel to get at the moment. Just wondering because the samsung is an older model is it worth getting it or should I go for a newer version.
