22" LED with DLNA - Is there such a thing?
benjamine1979
Hi All,
Im after a 22" LED for the kitchen and would like to pick up my server. So I am also after DLNA. I have spent a ridiculous amount of time looking but nothing, zip, diddle.
Anybody know of such a machine?
next010
Probably wont find one, media players tend to appear in only 30" or higher models. A lot of 22" displays are just computer monitors re-purposed as TV's.
It would be easier to just buy a very small media player for use with the TV, would have better media compatibility too.
IanM
I've got a Sony KDL-22E5300 (discontinued last Spring) that handles DNLA:
KDL-22E5300 (KDL22E5300) : Overview : TV & Home Cinema : Sony
However it sounds like some people have had problems using it:
http://www.avforums.com/forums/lcd-led-lcd-tvs/938204-sony-e5500-e5300-series-thread.html
It has a fantastic spec for such a small TV and in some respect is probably better than the current 22" models. As well as DNLA it uses the Bravia Engine 3 to give a great picture. Its looks aren't exactly conventional but may suit a kitchen (I have mine in a white conservatory).
It may be too late to find one new, and its DNLA may not be up to the job, but it is a 22" TV with DNLA, so may be what you are after.
Hope this helps,
Ian
gharbach
Just stumbled across this post as I'm also looking for a 22" DLNA TV.
The Cello model above sounds like a steal, but does it support DLNA, or just a form of media sharing? I can't find anything to suggest it's DLNA certified...would be great to know for sure...
