22" lcd with twin tuner & dvi ???
Discussion in 'LCD & LED LCD TVs Forum' started by loorenzo, Jun 28, 2004.
Tags:
  1. loorenzo
    loorenzo
    i was thinking to buy the samsung lw 22a13wx but its only analogue tuner
    the sharp lc 22sv2e has twin tuner but no pc link
    any suggestions
    thanks
  2. nealb
    nealb
    Nov 15, 2002
    194
    +5
    i bought a 23" philips with DVD recorder from unbeatable for £1080 and a netgem freeview box for about £55 to go with it.
    Not the ideal solution but quality really is excellent.
    Probably work out cheaper than freeview built into n LCD and it's easier to record from. More flexible than built in stuff and more than likley a better box than the built in stuff.
