21inch Sony TV black dot
Discussion in 'General TV Discussions Forum' started by jono, Aug 15, 2002.
  1. jono
    jono
    Mar 11, 2002
    22
    3
    I have 10 mouth old 21inch Sony TV KV21LS30, I have noticed a small black dot (dead phosphorus) on the screen in the middle to the left, the mark is always there no matter which picture source is on. Is there a way to get rid of it, is it a sign that CRT is failing.
  2. Squirrel God
    Squirrel God
    Most likely a defect in the phosphor coating.
    As it's only 10 months old, I would get in touch with your retailer as soon as possible.
  3. jono
    jono
    Mar 11, 2002
    22
    3
    Its from Currys would they try and fix it or would they replace it for a new TV
  4. Squirrel God
    Squirrel God
    I don't know. I guess they would try to repair it in the first instance but I'm not sure what that repair would involve or whether it would be practical so you may end up with a new TV.
    Definitely get in touch - don't put up with that dot!
  5. rupbert
    rupbert
    Jun 24, 2002
    544
    +18
    How do you rate this television? jono?
  6. jono
    jono
    Mar 11, 2002
    22
    3
    When you get a good one its great. Good picture on the flatscreen and sound is good. But am on my 3rd set. The first one I had the picture was slighting to the left and the TV option to twist the picture could not correct it. Then second one had a sound fault every time I changed channel the sound would go very low and then take a minute to build up to the level I had set the TV on. Now on my third one with this black spot, am tempted to stick will this one as I dread to think what fault another one could have. Its put me off Sony for good.
  7. jono
    jono
    Mar 11, 2002
    22
    3
    I've got a Currys engineer coming round tomorrow to look at the set, what are Currys engineer like.
  8. MLAM
    MLAM
    Dec 16, 2001
    627
    28
    South Wales
    +74
    I've had them come out to weld the soldering pannels on my Sony 29" TV and they did a good job of it.
    Also they repaid my old JVC VCR once when a Circuit protector broke.
    In general they should be ok
  9. jono
    jono
    Mar 11, 2002
    22
    3
    Engineer came this morning, it needs a new tube so just waiting for it to be picked up now.
