21065L DSP Question
Discussion in 'TAG McLaren Audio Owners' Forum' started by Miron, Jul 18, 2004.
  1. Miron
    Miron
    Sep 26, 2002
    1,435
    Vienna, Austria
    +54
    just one simple question for those who might know this (Udo, Steve, Mark ...)
    When TAG / IAG is doing DP upgrade and you find .2 DSP inside, is it exchanged for .3 or not ?
    Asking this since I know .2 had some problems, for an example not recognizing incoming signal so changing input and back was necessary, or processing crashing or whatever else ...
  2. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    The original (1999ish) .2 Silicon 21065L gets replaced when going to DP and also when sticking a DAB module in the thing.
    Now that separates the men from the boys when resoldering a new one of those things in! :)
  3. TaxHamster
    TaxHamster
    Jul 8, 2004
    39
    11
    +10
    C'mon Steve, you know it's quite an easy job to change a 21065 ;)
  4. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    Only for supercats like the masked Fleapit - soldering iron in one paw, SHARC in another and his partner in crime the hamster can run round the board afterwards checking for bridges and cat hairs! :)
