2105 and tuner problems
canardo
Amp still works fine however when I goto tuner mode it just sits there if I press the band button it alters between in tuner and ext in tuner
anyway I can reset it so the radio appears again!
Jase
You can reset the Amp back to the factory defaults. When it's powered off, hold down the Speaker A and Speaker B buttons on the front panel then turn the power back on. Hold the buttons a few seconds and the display will flash and reset everything. Just bear in mind you'll have to redo ALL your setup again.
