21" CRT TV DVD/Combi Wall Mount ?
Discussion in 'TVs' started by plan2change, Apr 10, 2005.
  1. plan2change
    plan2change
    Hello
    Need a TV for the bedroom and budget may not stretch to LCD/TFT etc
    Have noticed that Philips & Mitsubishi do 21" CRT TV DVD/Combi units.
    However as I want to wall mount it and tilt it I am presuming that these TVs with DVDs are designed to be on a firm & level surface and the DVD would possibly fall out of the tray. Am I correct in this assumption ?
    Are there any CRT TVs which have DVD units that can be tilted somewhat also possibly region free.
    Many thanks for any assistance
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    for a wall mount see www.unicol.com they do specific mounts for almost every CRT TV available but do look a bit industrial...........
  3. curious_george
    curious_george
    Sep 3, 2004
    25
    My IKEA catalogue has one, at an amazingly cheap price. You apparently bind the TV down with a cloth belt but it seems to work.
