206 install trouble
Discussion in 'Video Streaming Boxes & Services' started by boultz, Aug 25, 2004.
  1. boultz
    boultz
    having trouble with my 206 and sony stereo.
    stereo going in is sony xr - ca430x wiring seemed easy enough took straght out of factory fit stereo and put into back of sony. (same connectors unless i'm stupid)
    when the volume is turned up on the sony past around half way the power cuts stereo turns off and then back on.... is there some kind of limiter on the 206 that i need to bypass really want this in as have got all the other wiring done i.e. 6x9 and cd changer now want to get my sub and amp in???
    any help please :mad:
  2. DaveA
    DaveA
    Aug 26, 2004
    70
    Chester
    Could be you got the main power and switched power cables the wrong way round. Check em with a multimeter. Had this issue myself when moving a HU from a Pug to an Audi.
    It should be easy to switch them if necessary by using a small screwdriver to release the metal blades from the plug and swopping their positions.
    Good luck.
    Sony seem quite good at changing round their cables.
  3. boultz
    boultz
    had the cbles tested with a meter but may aswell try it n e way.... have also been told that it might be factory speackers giving to much feedback could this cause a problem?
  4. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    If the switch and permenant were reversed it would result in the loss of stored settings when powering off.
    It sounds like a protection device is being activated on the Sony, can you try it with different speakers, on the front channels first then on the rear. Also check for a short on the speaker wireing.
