As the title suggests, I am looking for a 2021 One Connect Cable longer than 5m for my QN95A.
2.5m comes in the box. I also purchased the 5m separately, but that was half a metre short.
I then asked the question if the 2020 10m One Connect will work in this 2021 QN95A on the Samsung Forums, where I got no reply, so went ahead and purchased the 2020 10 metre cable at £499 (here) to test on my 2021 QN95A, and despite my optimism, it did not work.
So, I now know the 2020 10m cable will not work on 2021 TV's.
I am now 'desperate' in finding a solution, so wondering if anybody has any guidance on this, so I can get it mounted on the wall?
I should mention, the 2020 cable and 2021 cable connectors look identical when looking at them physically. They also fit into their respective ports. I wonder if it's something software level that is blocking them from working. The 202 cable box does advertise it can support up to 8K and has 40GBps bandwidth - same as 2021 cable.
Just to re-cap, I've already purchased the 2021 5m cable, but that isn't long enough for the run while the 2020 10m cable did not work at all on the QN95A.
