2018 Samsung QLED One Connector Cable Strip Down
Discussion in 'Plasma TVs Forum' started by clemensfischer, Jun 30, 2018.
  1. clemensfischer
    clemensfischer
    Jun 14, 2018
    3
    Vienna
    Dear Folks!
    I am planning to get the 2018 Samsung QLED Q9FN. Unfortunately my wall hoses have just 20cm inner diameter. Plenty enough space for the cable, but no way to get the connector trough the conduit. Did anyone try to strip down the connector and rebuild it successfully? Or is there any other alternative?
    Thanks for your reply!
