EcoViewer
Just a quick question...
With advice from the forum members I have ordered a Panasonic tx-50EX750b. The plan was for this to be our second telly, wall mounted in our dining room.
Our current ‘main’ TV is a two year old Sony KD-49X8309C. We are quite happy with this where it is, but it got me thinking...
In deciding to buy the EX750 I disregarded various alternatives including the 2017 Sony XE80/83 models, as the Panny seemed to have a better spec.
Although it was cheaper, is it likely that the new Panasonic will be better than our existing Sony? If so, is it likely to be noticeable?
I know I could wait for delivery and run them side by side, but if the difference is obvious to you guys I may as well move the Sony to the dining room now and set the better TV up in the lounge. If they are pretty similar, the Sony can stay where it is.
Both TVs will be used for watching a mixture of content often on HD channels through VM cable, HD sport on BT sport HD, DVDs and possibly UHD stuff in the future.
Thanks!
Thanks!
