2015 LG v 2020 Panasonic/Hisense
roman700
Hello
I'd be grateful for your thoughts...
We have a 32" LCD TV from LG, Full HD, purchased in 2015. We have been happy with it generally in that time, detail/colours etc, remote, ease of use, Smart TV features - all good really.
We are now in a different house and feel 32" is a bit small. We've lived with it for a year without complaint really (I personally don't watch all that much TV but others in the family do). However, a thorough review of my TV/hifi set up does suggest it is a bit small and I am getting in to TV a bit more now.
Essentially we're a bit further away from the screen than we were in the old house, and the screen is a little on the small side.
Unfortunately, 43" TVs are a bit too big for the space, the TV will go in an alcove. 40" would be fine, but there aren't many of them around.
I found the Panasonic TX-40HX800 which I think has quite poor viewing angles according to some review. A good viewing angle would be important, most of the family will be well off-centre most of the time. Price is also a little high, but manageable maybe. I've rejected this model based on these factors...
I also found the Hisense 40a5600. This is much cheaper, and from a brand that I perceive to offer lower quality (despite some good reviews of higher spec models on this site).
I am not sure whether the benefit of this "big" screen would outweigh the good performance that our current old LG offers (albeit in a screen that is a bit on the small side). Is the Hisense a quality product?
Content at the moment is mostly Freeview HD, youtube videos, iPlayer, occasional Netflix/Prime video. DVD player hooked up to it, and a Nintendo Switch, neither of those are used all that often.
Thanks, interested in your views...
vickster
Is a 43 really too big? In what dimension? Width, height (I’d ignore the diagonal 43” when measuring).
Can you stick a bigger, better TV on a stand in front of the alcove?
roman700
I picked a 43" LG and it's a bit too wide. There may be slightly narrower 43" but side ports such as HDMI may make plugging in tricky.
Perhaps I'll remeasure as I want to make it work, but it could be impossible.
In front is difficult as there is a cupboard under the shelf the TV...
Thank you vickster.
vickster
This might give you some pointers of what to look at
The Panasonic's under TVs struggle to recommend
Dodgexander
I think all 40" TVs use VA type panels and won't have wide viewing angles. You'll want to fit a 43" if you can, although 43" like 32" are not high quality TVs nowadays, so you may just be better keeping with what you have unless you can go for a 49"/48" or 55".
roman700
Thank you!
Podcast: Sony A90J Thoughts, madVR Processor & Sonus faber Lumina II Reviews + Movie & TV roundup
