2013 airport extreme - anyone tried one yet?
Discussion in 'Apple Forum' started by blue max, Aug 9, 2013.
  1. blue max
    blue max
    Apr 12, 2006
    12,928
    London
    +4,299
    And what did it replace?
    I'm wondering if it solved anyone's issues in difficult wifi circumstances. IE replaced a Gen 5 with it and amazed at the difference, sort of conclusions.
    In the real world, does it perform.
  2. CamFire
    CamFire
    Apr 26, 2009
    4,693
    Cambridge
    +600
  3. blue max
    blue max
    Apr 12, 2006
    12,928
    London
    +4,299
  4. tvmonkey
    tvmonkey
    Nov 7, 2007
    878
    Aberdeen
    +63
    It's i.e. by the way.
  5. blue max
    blue max
    Apr 12, 2006
    12,928
    London
    +4,299
    Glad my grammar has been cleared up. Anyone bought a new airport extreme?
  6. magoo1
    magoo1
    Apr 14, 2006
    454
    +56
    Well I've got a new 2Tb time capsule. Same thing with a HDD inside. Works fine. Simple set-up and have ample signal all over the house. :smashin:
  7. CamFire
    CamFire
    Apr 26, 2009
    4,693
    Cambridge
    +600
    Tests during reviews showed that the wireless range on the 2.4GHz is improved and the net (wired) LAN speed increases, meaning faster transfers (file transfers, backups, copying, etc.) within your local network. Are you seeing these?
    There is a hint of lower performance on the WAN side - but this doesn't matter a lot since the available bandwidth is high enough for the ADSL/fibre lines anyway.
  8. blue max
    blue max
    Apr 12, 2006
    12,928
    London
    +4,299
    Thanks for the response. Did you have a previous version before... I am trying to get some feedback whether it is actually a significant improvement.
  9. magoo1
    magoo1
    Apr 14, 2006
    454
    +56
    It replaced a 802.11n airport express. I cant say i've noticed any real increase in speed or range but when I slowly upgrade to 802.11ac kit I'll see the benefit.
