Under 200Hz, select custom and disable judder reduction.
The new Samsung allows user to adjust low-level and high-level MCFI separately
Don't use Game Mode because it does't allow you to select WARM 1 or 2. Instead, use PC Mode
http://www.avforums.com/forums/lcd-...ag-new-samsung-led-well-series-5-6-7-8-a.html
Thanks, I'll try judder reduction and see if the girlfriend is happy with it.
I haven't had much chance to game on it, but did see that thread about using PC mode before and have been meaning to try it.
It's virtually impossible to check in store due to large amount of variables. Also, you have to implement panel lottery into the factor.
I disagree on this point, unlike some other picture parameters where ambient lighting etc make it difficult to make a good judgement instore, I tihnk you can with motion handling.
It does take a little effort/planning but i've done it in the past. You either have to take the material you watch with you on DVD/BD or wait for it to be on (i.e football).
While you obviously can't get the full picture (pun intended) you can get a very good idea if one set stands out to you.
If you ask nicely, I've found you will find a salesman who will alow you to stick your own DVD/BD in. Or switch feeds (I've had them plug the Sky HD box into a couple of different sets). Obviously you need to narrow your choices first, you cant take the p**s and spend the day messing with every set (well maybe if you spend alot of money with them regularly).
WRT panel lottery, that applies to any review, wether that be your own or a commercial review. Infact I feel I'd have a better chance of determining the variation in panels by visting the dozen or so stores with 15 mins of me, then reading a dozen reviews all of who'm may have seen the same review sample.
With LCDs, there's no way to blur free motion due to variable pixel transition times.
So we are stuck with MCFI. That is until next generation of LCDs introduced for the consumer market
Search Keywords: Samsung Blue Phase LCD and FLCD
Hopefully it delivers the performance Samsung is touting.
