2007 Audi A3 1.6 FSI Airbag light
steff88
I have just come back from holiday and my car wouldn't start, it was turning over but the battery was a bit weak, i jump started the car and the abs, and airbag lights came on, the abs light has since gone out, but the airbag has not - any ideas on how to clear this? There is no fault with the airbag, it was fine prior to the holiday and i have owned the car since new without any prior problems of this nature.
Stephen
ukdan
Established Member
Only way to clear the warning light is to use a diagnostic kit like VCDS. More than likely it was only the flat battery that's caused it.
See the sticky thread at top of page.
Solomon Grundy
Take it to a garage, they will switch the light off for you if they have the correct equipment.
Amazon Fire TV Cube Gen 3 Review: Coming Soon
