200 vs 300 watts
Discussion in 'Hi-Fi Stereo Systems & Separates' started by ch2s, Dec 28, 2002.
  1. ch2s
    ch2s
    Dec 28, 2002
    7
    As I said in an earlier post I want to buy a sony minisystem but it's only 200 watts compared to my current 300 watt system but the sony has 6 inch woofers and mine has 5 inch woofers.
    Will the sony system have a much lower volume than my JVC or will it be about the same since they have larger woofers?
    And would adding a 100 watt sub to the sony make it louder than my old system?
  2. mjn
    mjn
    May 24, 2001
    18,000
    Herts, England
    +4,977
    is this a joke post?
  3. ch2s
    ch2s
    Dec 28, 2002
    7
    No why? Could you please answer I am planning on buying the sony system today.
  4. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    Normally Mini systems are frowned upon..... the question of power ratings is pointless for a mini system since they are artificially infalted so untrustworthy. Volume is not a function of power anyhow. You cannot in any way predict the volume of a given minisystem so dont even try!
    ad
  5. chino
    chino
    You'll probably end up with less woof per inch with the sony system.
    Volume is directly proportional to the power output divided by the woofer inches. :p
  6. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    no it isnt.
    Imagine two 12inch woofers A and B
    Both woofers are 'near' identical, except:
    woofer A has a sensitivity of 86 Dba
    woofer B has a sensitivity of 93 Dba
    Woofer B would be louder at any given power level.
    A crude example, but it still aplies. The fact is, Volume is not directly proportional to the power output divided by the woofer inches, Because there are too many other variables to consider. Sensitivity being a very important one as far as this arguemnt goes.
    also i totally agree with buns. wattage rating in systems of that callibre are extreamly inflated and can never be trusted.
    I would personally try to listen to both systems before i made the decision, or otherwise find reviews of them to compare the two.
  7. ditton15
    ditton15
    Oct 20, 2002
    535
    16
    edinburgh
    ch2s
    Confused?
    The reason for this is obscure, that's why the higher the fewer.
    Ditton
  8. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    I think Chino was taking the Michael! :p
    ad
  9. chino
    chino
    Well observed!!
    James, I completely agree with you on the sensitivity issue. I believe that as it is measured in db it is a logarithmic scale. i.e. 100db is not twice as loud as 50db, it will in fact be more than twice as loud.
    Chino
  10. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    it is in fact closer to 24 times louder (an increase of 10db is viewed as being twices as loud - so 60db is twice as loud as 50db, 70db is twice as loud as 60dd and so on)
  11. nathan_silly
    nathan_silly
    Gimme more power scotty!
    Have a look in the spec of midi systems.. 10% THD. Fried speakers anyone?
  12. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    lol yeah dont about forget that. you would probably be closer to half their rated power when properly (like 0.1% THD, not 10%!)
  13. nathan_silly
    nathan_silly
    Midi systems are usually quoted as
    Rated Power into 6ohm, 1 Khz tone, DIN xxx W at 10 %THD.
    Compare that with the standard both channels driven into 8 Ohm, full sweep, xxx RMS at 0.05% THD.
  14. ch2s
    ch2s
    Dec 28, 2002
    7
    I just looked at the specs and the sony minisystem I got is less than 0.09 THD for the main front speakers.
  15. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    You guys kill me. This is one of the most delightfully entertaining threads I've read in a long while, and I don't even know what the frick is going on. It's so Monty Python.
  16. WhyAyeMan
    WhyAyeMan
    Jul 4, 2002
    3,004
    Newcastle
    +276
    Is that at 1 watt? :p
  17. ch2s
    ch2s
    Dec 28, 2002
    7
    Thats at 35 Watts, the speakers are 60 watts.
  18. ditton15
    ditton15
    Oct 20, 2002
    535
    16
    edinburgh
    yeah, but if I'm trying to measure the wattage of an analogue stereo amp do I have to use a slide rule for the logarithmic transform; if so, anyone on these Boards seen any going S/H?
    ditton
  19. Gambit
    Gambit
    How bored were you last night Pointon? I love your angry posts and today I find them where ever I go. 'Tiss very funny.
    Look, guys, everyone know that speaker loudness is related to a)how big the cabinets are- the bigger the louder b)how much their prescence ****es your missus off and c) what colour the cones are painted- red= very loud. Sony all ways use red on their loud systems.
  20. karkus30
    karkus30
    Jul 29, 2002
    13,991
    +1,261
    But what about the Watts, are they British standard large or Japanese small. Just like eggs.
  21. ditton15
    ditton15
    Oct 20, 2002
    535
    16
    edinburgh
    They are of course Scots; being named after the fella who invented the kettle.
    ditton
  22. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    What coronation street got to do with this! :p
    ad
