20" HD Ready, widescreen LCD with Freeview?
Urien Rheged
I have done some searches on the forum and can't find much on this subject.
Can anyone recommend a 20" or less, HD Ready, widescreen LCD TV with built in Freeview?
:lease:
Many Thanks
[email protected]
:lease:
Many Thanks
Theres quite a few from the major players, including the cheap brands like whafedale and other OEM brands. Couple of good model examples would be :
Sony KDL20S2020/2030
JVC LT20DA6
Both have reviews on the Homecinemachoice website.
Urien Rheged
Thanks. :thumbsup:
It does seem to be a LOT more expensive to get one with built in Freeview? The two you have mentioned are in the £410 - £450 price range. You can get a decent HD Ready 19" Samsung without Freeview for £237.49.
Are there any other cheaper alternatives from the decent manufacturers?
Steve1951
I think one of your options has to go for the money.
Knock off the HD ready and your choice goes right up.
I understand the wish for HD but its only a 20" after all.
Steve
Urien Rheged
RockySpieler
The 19" ones I've seen in shops (with laptop resolution screens) did not have very good viewing angles.
Make sure you demo before buying.
And of course give a review of the one you decide upon, once you happy with it.
Urien Rheged
