2 zones 8 ceiling speakers
gpl13
One zone in the living room with 4 in-ceiling speakers, the second zone would be an outdoor covered deck, also 4 ceiling speakers. I am wondering what receiver I could purchase to accommodate this? I want the 2 zones to be able to play different sources at the same time. I would like it to be google home/assistant compatible. Living room would be primarily for tv sound with the option of streaming music when tv not in use. The deck would be primarily streaming music.
So what budget friendly receiver would be ideal?
Seb Briggs
Ive recently started recommending and installing the Arylic A50 wifi amplifier, you would need 2 obviously
gpl13
Sbriggs thanks very much for your suggestion. This could well be a good, budget friendly solution. Being very new to this all, how would I go about hooking up 4 speakers to one unit and 4 to another. They look like they only have 2 inputs on the arylic. Also factoring in how to get the volume from the tv going thru the device?
Thanks again
Seb Briggs
What speakers and their impedance will determine how you can wire the speakers, though it should be possible to wire 4 speakers.
The amplifiers have stereo audio in for TV input
Seb Briggs
Left Channel
Right Channel
If the speakers are 8Ohm, as the amplifier supports 4Ohm output, they can be wired in parallel.
LG G1 OLED Evo TV and SVS SB-1000 Pro subwoofer reviews, Samsung OLED rumours and more...
