Okay so it's taken a good while to get things done, but now the dream is being realised.
The only issue in the building process is that we have changed the orientation of the room, which has reduced the throw distance quite a bit.
So what projector, mount and screen? Looking around £600-800 all in.
Ceiling mounted.
Max screen size: 240cm wide, 150cm high.
Throw distance: 200-220cm
It doesn't matter if I don't use the full size, but I'd like to use most of it. Mainly for DVD and blueray, possibly occasional x-box. There is only one small window about 3m from the screen on the same wall, so very little natural light.
Hoping to save up and get something around Christmas/January.Recommendations? Thoughts?
Thanks very.much.
Ceiling mounted.
Thanks very.much.
