2 xboxes 1 NTL connection - problems
Discussion in 'Cable TV & Virgin Media TV' started by monkeyleader, Jan 14, 2005.
  1. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    Hey,
    So my mates round 2nite with his xbox .. we are trying to get some halo2 action on the pipe but problems galore - does anyone know if there are issues with 2 xboxes on the same broadband connection - its a 1.5mb connection and if we go one it one at a time no problems - it just chucks us out one at a time at various points in a game ...
    Any ideas ?
    Nige
  2. ozzyo99
    ozzyo99
    Dec 31, 2002
    155
    London
    +3
    Well you will be needing a router and you need to ensure DHCP is enabled or manually alocate IP and DNS. Im not quite sure about what your trying to do though as you havent detailed it.
    Are you trying to both sign-on Live?
    Are you just system-linking to do Co-op?
    Do you like red meat?
    All these questions need answering really before i am able to help.
  3. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    i have a router .. all dhcp enabled ... co-op works fine ... its when we are both on live - we can sign in etc and start a game etc ... but after about 2 minutes one of us gets kicked ...and yer steak and lamb !
  4. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,941
    2
    Manchester
    +4,459
    Only a thought, but make sure both the Xboxes have the same MAC address entered as NTL only allows one machine online at any one time (unless you sign up to the Live package for £3 a month or whatever it is).
  5. Sparkyuk
    Sparkyuk
    The NTL DHCP server should only see the MAC address of the router. I think this is going to be a problem with either your router not handling the packet routing properly or XBL having problems with 2 account requests coming from the same public IP.
  6. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    Could be as simple as losing the connection due to the pitiful 128K upload split between 2 boxes?
  7. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,941
    2
    Manchester
    +4,459
    The NTL 1.5mb connection has a 256kb upstream connection IIRC...
  8. thebigkung
    thebigkung
    Have you any Pc's.
    If you can play with a PC online and and xbox online or if you can play with 2 pc's online with no problems, then this'll prove that it's XBL that is not liking the 2 accounts from the one simultaneous NTL i/p
  9. DarkEntity
    DarkEntity
    Feb 13, 2005
    2,438
    3
    87
    Glasgow
    +445
    why not just manually configure the lot?
    i tried to let xblive configure mine then gave up and dont it myself.
    im on blueyonder bb and ive had 3 xbox's on live via one account.
    (ps i dont have a router)
    i have 1 pc with 2 nic's one going to bb other to network switch.
    i then turned on packet routing within XP Pro and manually configured the rest using the PC as the gateway.
  10. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    i have had 10 PCs on this connection without problems - its defo an xblive account issue from one bb account ...
