2 x scart into single plasma component input
Discussion in 'Plasma TVs' started by FaxFan2002, Nov 10, 2003.
  1. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,132
    63
    Andover
    +110
    Not via a AV amp, but a switch box or whatever..
    How? is it possible?
  2. nealgs
    nealgs
    We have dvd->sky box->JS Tech RGB2YUV->Plasma
    have amp after JS Tech box, but remove amp will give you the result.
    Gary
  3. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    My! What a lot of gear you've got! I should get a scart switch box, Lektropacks or Keene, and then via a JS RGB-YUV adapter. All scarts will have to be RGB, you need the adapters as appropriate for the consoles.
  4. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,132
    63
    Andover
    +110
    Not for me (I switch everything thru the denon amp with up converts to component). For ma & pa who taking a tentative step towards plasma...
  5. Arshad
    Arshad
    Hi guys,
    I just installed the broadband tv set-top box and it has a component out but my tv only has one component input. I have the onkyo 601 receiver though and it has 3 components.
    Can I somehow use the component input of my onkyo amp to send the signal to my tv?
    The guy who intalled it for me used the composite video in but I changed it to s video, wondering if component would be much better?
    What is the use of so many inputs on the amp. though, it has 3 compoennts, about 8 s video, and many composite out? Does the inputs or outpouts on the amp. mean if I have limited inputs on my tv, I can use the inputs or outputs of my amp?
    By the way, what is the highest resolution component cables can handle, i know it can handle 480p and 576p but does it support 720p or 1080i?
    Any suggestions?
  6. ASH1
    ASH1
    Mar 1, 2003
    1,208
    +61
    Hi Gary, are you all up and running now? If so PM me some pics.
    ASH1 :smashin:
