2 X Bullet camera clean video switching?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by White_Noise, Oct 27, 2005.
  1. White_Noise
    White_Noise
    o.k this is the first post so be nice! :hiya:
    i have a problem and wonder if anyone can help out, i have been thinking about putting a camera system on my motorbike, but with two cameras going to a splitter box and then onto a DV camera. the splitter box would have a handlebar mounted switch that would determine which camera was in use at the time by switching between the two camera inputs, thinking that a relay will be best t0 do the remote switching, but there is going to be a massive transients occuring when the switching takes place. so i am looking for a way to perform the switching smoothly by creating an 'electronic' crossfade from one signal to the other. anyone got any ideas how this can be ahieved that could help me out?
    WN
  2. DigiStuff
    DigiStuff
    Jan 22, 2002
    151
    Can't help you out directly but check out www.keene.co.uk. If what you are after is available these guys will have it!
    Regards
    DigiStuff
  3. ctcrm
    ctcrm
    May 6, 2003
    134
    get one of those cheepo camera switchers from b&q or maplins ?
  4. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    I can shed some light...
    It will be very difficlut to do. well, properly!
    You will always get a slight shift when switching video unless you have a couple of things correct.
    1. video timing need to be the same for both cameras and switcher. known as genlock.
    2. line 7 switching. which is when the switcher will cut cleanly at the right time.
    There is something called the 8 field sequence where you get a shift in picture also...
    How much is your budget?
    you could get hold of 2 cheap camcorders with ext i/p on ebay, and edit between them? of course, you will have issues with sync!
    I believe the setup for the GS adventures for the long way round had switching manually between helmet and bike cams. I am actally thinking of getting into this field of work as I am a biker and a broadcast engineer!
    Let me know if you fancy throwing some money at it, and I could look into what you can get.
    Regards,
    Gareth.
