That's what they should look like
What drivers to go for and amp. Appreciate any input
That's the ones i heard them with, sounded brilliant.I have SI15 drivers in my two powered by an Inuke 6000
Works for me![]()
I was thinking 1 cv5000 with fi Q drivers and antimode cinema. Or Behringer-NU6000DSP-Inuke-Amplifier with si ht drivers and antimode cinema.If you wanted to go all out then look at 2 fi sp415's dual 1ohm but then you will need 2x cv5000's to power them at 5000wrms should give them plenty of headroom!! Giving you more output than a usc18.
No mike, i have never used REW but willing to give it a tryHave you considered how you are going to setup 2 subs? Do you have a mic for example?
It will be in the same room but I can hide it, budget will be around £1400What's the budget you're working to?
Assuming you're looking for a separate amp, will it be in-room, in-cabinet or in another room?
if you went fi q then an nu6000 would be enough, but bear in mind they have a little more output then the si but not as clean sounding.I was thinking 1 cv5000 with fi Q drivers and antimode cinema. Or Behringer-NU6000DSP-Inuke-Amplifier with si ht drivers and antimode cinema.
have you used the rew room sim? it would be an interesting starting point to compare against 1 sub.No mike, i have never used REW but willing to give it a try
Make sure you post some pics.The cabinets' are going away next week to get painted, black pearl.
I'm just reading about REW it Will Take Me some time to get my head around it. What do I need to use REW.have you used the rew room sim? it would be an interesting starting point to compare against 1 sub.
Will doMake sure you post some pics.
Minimally a known SPL meter (ie has a calibration file, typically means the rs meter) and a soundcard with a line in.I'm just reading about REW it Will Take Me some time to get my head around it. What do I need to use REW.
I've got an SPL meter, what sound card do you recommendMinimally a known SPL meter (ie has a calibration file, typically means the rs meter) and a soundcard with a line in.
Next step up would be to a USB mic, i.e. the minidsp umik-1.
Next step up would be a phantom powered mic and pre amp (eg Dayton audio emm-6).
Personally I prefer the first or last option for multi sub setup but plenty of people manage fine with the USB option.
To use the room sim takes no effort. You just plug the numbers in and move the positions around to match your room.
I think the behringer uca202 is meant to be a solid cheap option (£20-25). I have never used it though.I've got an SPL meter, what sound card do you recommend
What mike do you use with that.This is what I use
Behringer UCA202 U-Control Ultra low-latency 2 In/2 Out USB/Audio Interface by Behringer Behringer UCA202 U-Control Ultra low-latency 2 In/2 Out USB/Audio Interface: Amazon.co.uk: Musical Instruments
So as I radio shack meter I just need a sound card. And some sort of lead.Just the RadioShack spl meter, I also have an anthem usb mic but for what you need the spl meter will be fine
