alitech
Hi guys
I have dabbled with home automation and have been playing around with smartthings for a little while. It is not a hugely robust system but I persevere. I have some automatic bathroom and store lights. I also have hue and hive systems and also ring doorbell. So a lot of systems that dont play well together but whatever, I am ok for now.
I want want to start installing some smart switches in my walls. I know of fibaro dimmer 2 and shelly etc. I want them to integrate with smartthings and alexa.
Does anyone know if i can control 2 light switches with a single fibaro device?
Here is what my wall plate looks like. On the left is just a light switch and on the right is a dimmer switch. Its a press and hold type switch.
I can put a momentary switches in place of these as I understand that is whats needed for fibaro. Can anyone shed some light on fibaro dimmer 2. Can I use one to control both switches or do I need to do something else to achieve that?
I have 48mm back box by the way, so plenty of space to fit in some stuff. The plate and modules are euro modules.
