2 subs??
Discussion in 'Subwoofers' started by diesel, Apr 8, 2002.
  1. diesel
    diesel
    Feb 2, 2002
    736
    West Yorkshire
    +58
    Sorry if this is a dumb question, but an opportunity has arisen for me to purchase (cheaply) a 2nd M&K VX100 Sub.
    My question is this: I have a Sony STRDB 1070 Amp, is it possible to run 2 subs from this amp, is it worth doing and how do I do it?
    Okay so I cheated and theres more than one question:D
    Can anyone offer an opinion plz:confused:
  2. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,211
    3
    +8,314
    It maybe an idea to ask to try out the second sub before buying. I recently purchased a cheap second Rel Storm, but had major hassles getting it right. In the end I decided to get rid of it.
  3. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,211
    3
    +8,314
    Sorry
    As for connecting to the amp, if you only have one phono output then buy a y splitter from maplins which will do the job for you.
  4. diesel
    diesel
    Feb 2, 2002
    736
    West Yorkshire
    +58
    flippin heck ur up late m8. Thanx for the reply. Is this the way most peeps connect 2 subs or do some amps have 2 connections?
  5. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Some amps have indeed two connections, well, mine has actually three: L, R and mono. (Yamaha DSP-A1)
  6. Lowrider
    Lowrider
    I had my REL Strata IIIs connected using a cheap Y splitter, replaced it with a monster cable T splitter and the bass improved significantly, about 20 pounds a pair...
