2 Subs
tulloch2003
Hi all can you connect 2 subs, one from your amp then the other from the left or right phono at the back. Will this work then.
Regards Tulloch
Knyght_byte
you mean you want 2 subs getting the same signal? if so just use a Y splitter cable (single RCA to twin RCA) with the single RCA going in to the Sub out on the amp and the other ends going in to your subs low level inputs......obviously you might need to buy a couple of single phono extension cables to reach if they far apart....
altho some subs might have a passthrough, like daisychaining monobloc amps, you put the signal from amp to one sub, then that sub passes on to the other sub.....i dont know about that myself tho, so best let others answer if thats what you want to know...
Trending threads
