2 subs... How do I set them up ?
Discussion in 'Subwoofers' started by Mad Max, Jun 18, 2001.
  1. Mad Max
    Mad Max
    Connectionwise, how the hell do I connect 2 subs ? I only have one .1 channel........
    Thanks for help
    Max
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    If one of the sub's doesn't have a line out to daisy-chain the two subs use a Y-adapter cable from the AV amp's subwoofer output.
    Those cables should be available at electronic stores or your hifi/AV dealer.
  3. Afc666
    Afc666
    May 2, 2007
    58
    im trying to set up 2 subs as well, i have a denon 1905 reciever, yamaha sw1500 and a bose subwoofer as well, how do i connect them to my amp so they both work as subs togather?
  4. chrisgeary
    chrisgeary
    Jul 23, 2003
    2,686
    Newbury
    +218
    AFC666: you would connect your yamaha subwoofer to the sub output on the denon and your bose sub isnt so much a sub as the bass driver your cubes (i presume its a bose sub/sat speaker setup you have there). That being the case, treat your bose sub as part of your main speakers - i believe your sats wire into the sub?
  5. Afc666
    Afc666
    May 2, 2007
    58
    Thanks for the advice!i have the am15 bose sytem, and the cubes run of the bose base unit yes, so how do i run the bose as a front speaker if the place is already taken by my fronts?
  6. suniil
    suniil
    Jan 24, 2005
    4,948
    London SE5 / W1
    +402
    Search with keyword "splitter" in subwoofer section of this forum!
  7. Afc666
    Afc666
    May 2, 2007
    58
    hi, do you loose any sound quality or volume from the subs when connecting y adaptor?
