2 soundcards, bad idea?
Discussion in 'Computer Components' started by zAndy1, Jan 22, 2004.
  1. zAndy1
    zAndy1
    Nov 26, 2002
    21,980
    2
    5
    163
    +8,427
    Hi all,
    I'm having problems due to Showshifter and Maudio not talking to each other properly (Maudio drivers fault apparently). Could I add a soundblaster audigy2 or something and use that in Showshifter for the line-in but use the Maudio for everything else? Is it likely to cause any problems at all?
    Cheers,
    Andy.
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,263
    Manchester
    +755
    Whether they will "clash" depends on a couple of factors.
    1) Which interrupts they use ; this may be fixable by either using or not BIOS or Windoze' Plug 'n Play enumeration , or manual IRQ assigment (BIOS or Windows Device Manager) .
    2) This one ain't fixable : if both soundcards use the same or very similar WDM drivers then they cannot coexist.
    I cannot put a Brooktree-based TV tuner card in my PC at the same time as my Twinhan satellite tuner card because the satellite card uses BT drivers based on the same core code.
    I can (and do) have a 2nd satellite tuner card in the PC bedause it uses totally different drivers.
    So , to some extent, you may have to try it & see - unless someone else can be found with the same combination already to verify that it will work.
    Chris Muriel, Manchester.
