2 Sky+ boxes in the same room
Discussion in 'Sky Digital TV Forum' started by sharper, Sep 26, 2003.
  1. sharper
    sharper
    Jul 24, 2002
    607
    SW London
    +11
    Remote codes are the same, according to sky tech.
    Any ideas?
  2. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    From what I've read Sky+ boxes uses different codes to normal Sky digiboxes. You could have one of each in the same room with no problems.
  3. sharper
    sharper
    Jul 24, 2002
    607
    SW London
    +11
    I have this set up already
    I would like to have two sky + boxes in the same room and I'm looking for a way around the remote codes being a real pain.
  4. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +975
    Quote taken from an earlier thread on the same subject:)
  5. sharper
    sharper
    Jul 24, 2002
    607
    SW London
    +11
    Don't know much about TVlink. Does it not use the IR and just send it from room to room. We have a similar thing which my son uses to access the function on both boxes (1x Sky+ and a Sony digibox) but that just relays the IR signal.
    And would not work also the pronto seem to be less directional and tends to operate from wherever you point it
