2 sky boxes 1 room
Discussion in 'Sky Digital TV Forum' started by Gazpoz, May 9, 2016.
  1. Gazpoz
    Gazpoz
    May 9, 2016
    5
    Belfast
    I have two sky boxes in one room side by side, is there a way that each remote will only operate one of the boxes? one boxes is a 2tb box and the other just a 500mb
    Many thanks
  2. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,344
    Redditch
    +4,143
  3. Gazpoz
    Gazpoz
    May 9, 2016
    5
    Belfast
    Thanks, I'll look in to this.. but I think my problem is that I have two boxes under the stairs going to a HDMI matrix going to each room in the house, I also have IR receivers in each room going to senders under the stairs which can see each box. I was thinking each sky box (different) would have a remote but this isn't true as you know.......
  4. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,344
    Redditch
    +4,143
    You may have to use a magic eye system just for remote control to provide individual control using the SPC4 unit.
    Much simpler using Humax Freesat/Freeview boxes as the remote controls have 6 operating modes so you can use 6 units without the remote controls clashing.
  5. neilball
    neilball
    Jan 7, 2005
    2,901
    Scottish Borders
    +637
    Have you already bought the matrix? If not look for a feature called routed IR - this means that IR receivers from each room only operate transmitters connected to the kit they have selected to feed that room. So if you watch Sky box 1 in Room 1 then only the IR emitter connected to Box 1 reacts to commands from room 1.
