2 sims 1 phone?
Discussion in 'Mobile Phones Forum' started by Baggy69, Feb 9, 2005.
  1. Baggy69
    Baggy69
    Mar 15, 2002
    187
    Birmingham, UK
    +3
    Ok i know about ghost sims where you can have 2 sims in 1 phone and switch from one to the other by turning off/on but are there any phones that accept 2 sims at once and you can have both numbers active at the same time? I ask this because work is just about to get me a phone and i dont want to carry 2 phones at once (personal and work(2 different networks)) and i dont want to miss calls by useing the ghost sim method.
    So is there any phones out there that can do this???
    Thanks Ian.
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,827
    Galactica C.I.C.
    +272
    If one of the phones allows you to divert calls when you are busy or not avalable, to another number.Then simply divert all calls from one phone to the other and hey presto you just need one phone. My sharp gx30I allows you to choose ,in the call diverts menu, where to send the calls. I send them to voice mail, but you could just as well send them to any other number you wish. :thumbsup:
