2 questions please
Discussion in 'AV Receivers & Amplifiers' started by Gadjet, Aug 3, 2004.
  1. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    First question is when watching Kill bill last night on Pioneer AX-10 had volume on -16 and the amp kept switching off. Admittedly it was loud but not deafining loud. As anyone any idea why amp kept switching off?
    Secondly, I will be setting up package in new house soon and I am wondering if connecting tv, sky and DVD through amp to NEC 100HT pj will I loose quality in picture because it has gone through amp. The DVD will be component in and out the other 2 will be s-video?
    As always your help is much appreciated,
    Phill
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I personally dont see a huge difference if quality cables are used. as for distance on the NEC take a look over at www.projectorcentral.com
  3. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    you are a star tonight with your help, cheers for your time,
    Phill
