2 phone landline setup
Elmer
Hi I wasn't quite sure where to ask this.
Are there any phones available where you can answer the phone on one phone and then transfer it to the other via an extension line.
It's in a fairly large building with the second room at the far end and up a floor so unfortunately the usual two phone cordless setup where both are getting their signal from the one base station and you can transfer from one to another wont work as the second room is out of range of the base station.
I have an extension run to the second room from the master socket which is in the first room. This is a normal bt line.
Elmer
Thanks for the reply
I think I might go for the BT Elements Weatherproof DECT Twin from that link, rather more than I wanted to spend, but looks like it should do the job.
