2 paradigm ps1000s or a rel 200/1?
Discussion in 'Subwoofers' started by astonbilla, Aug 9, 2002.
  1. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    Any ideas folks, i can get 2 paradigms for the price of a Q200e.
    Has anyone used 2 paradigms, and are they good in a pair?, better yet will they outperform the REL
    thanks guys
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,465
    United Kingdom
    +1,941
    The old chap has got a Paradigm PS1000 running with my old Q200. To be honest there´s not a huge difference between the two, the Rel goes a bit lower. I would have thought two PS1000´s would outperform a single Q200. It´s down to you but the Q200 needs to be tinkered around with to get the best out of it, the Paradigm was easier to setup in terms of bass performance (keep away from walls if possible).
  3. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    so the ps1000 is a good enough wee sub then?, i have a Denon 3802 and mission cinema 7 speakers.
    Im desperate for a sub so if this paradigm would do, then happy days are here again
    Wonder what Uncle Eric would make of this setup?, he knows his stuff.
  4. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,465
    United Kingdom
    +1,941
    I think you´ll find Uncle Eric is not keen on the Rel Q150/200/201.
    I must point out that your room will also have a huge effect on the sub performance. When I had the Q200 in mine (best spot in it, on spikes, marble slabs on top and tweaked over a long period!) it sounded better than in my old chaps place and paired with the PS1000. Never tried the PS1000 in my place so it´s possible that could sound even better than the Rel.
    Other options to consider are the Velodyne subs in the Power Buys Forum (CHT10). Supposed to be better than both the Paradigm and the Rel.:)
  5. GJC
    GJC
    Mar 1, 2002
    2,137
    London
    +69
    I'm surprised someone hasnt suggested you buy a Velodyne from the Power Buys forum;)
  6. GJC
    GJC
    Mar 1, 2002
    2,137
    London
    +69
    Sorry Jase - both reply's appeared on screen at the same time.
  7. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    Jase, isn't the crossover fixed on the velodyne?
    85 i think?, do laugh if i'm way off
  8. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,465
    United Kingdom
    +1,941
    That´s the high pass filter thats fixed. If you connect via low level (phono) from the sub out of your amp you can adjust the crossover to wherever you want (within its range obviously!).
  9. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    I know i sound like an idiot, but regardless of which sub i get - how should i hook it up. I mean, at all. I have neeeever had a sub nor fiddled with one. Are there any fundamentals i should know?
  10. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,465
    United Kingdom
    +1,941
    Easiest way is to use a phono cable from the subwoofer output of your amp into the low level input of the sub. Depending on what you have your speaker settings as (Large or Small) dictates what position you have the crossover set at, you can also ignore the subs crossover as well if you wish (it will be controlled by the amp). Then its a case of adjusting the volume to suit your taste (ears!!).:)
  11. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Both Jase and I have on one of astonbilla's previous posts on prospective sub purchases.
  12. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    well, call me picky then. I'm sure everyone puts in a lot of research before buying and you guys know more than any poxy review i have found.
    Sorry if i have pis*ed you off, but i don't want to buy something only to regret it later - like that guy who started off defending his Q150E to the hilt then all of a sudden became a novice on the matter... now what was his name?
